Activity Feed › Forums › Where should I start – Post drawings and questions › Layout questions
I got as far as the placement of the planks in the hallway to flow into the bedroom that day.
Hoping to finally get to it tomorrow
Thank you for the video. You had mentioned in the beginning that I should cut into the sheet rock. The bedroom has mdf baseboard that I haven’t been able to find more of. I think it’s glued on, and I suspect it would break if I tried to remove it. Does that change how you wanted me to proceed? I do have a multi tool, and was planning on putting quarter round around the edges.
Also, the wooden transition to the bathroom (it’s the same as in the hallway) – am I leaving 1/4” or going right up against it?
Thank you for such a detailed explanation.
I have a question about the entryway to the bathroom. I thought it was a similar transition, but it’s level. I’m going to assume that I would line up the boards even with what’s been done with the subfloor, then add a transition on top, because there will be a height difference.
There’s an inch clearance between he subfloor and the bottom of the door.
I think I can add captions to the photos.
