Where to Secure Flooring as installing.
Looking to see if I’m missing or overthinking the install. I’ve done Sold Hardwood install before, but that was simpler as I could staple and not worry about movement. I’m doing a Laminate install and want to do it without Transitions between rooms. In the drawing i show the main reference line and will be installing length wise throughout the bedrooms. Will be starting in Room 2. The Green lines are where I believe I need to secure the flooring and keep secure until the entire floor is installed. Am I missing anywhere, as for the first row’s I’ll use scrap pieces, then most likely screw along the edge for the other areas like in the hallway.
Any other advise is also welcome. I’ve chosen to start in room2 based on moving furniture and having to live around the install time.
