Activity Feed › Forums › Where should I start – Post drawings and questions › Troy’s floor plan
Hey Joe, sorry to bother you with this again lol. This should not be that hard obviously.
But this 4 inch overhang sticking out from the threshold into my garage is causing me a little problem/hold up. I wanted your opinion on this. Do I necessarily need a threshold at this door? It is not exposed to the elements, but it does block our home from cold and heat from the garage. I found a door sweep that adjusts to the gap between my plank and the bottom of the door and wondering if I can just install my plank clear out to the edge of the step And use this door sweep instead of a threshold?
Went to go purchase the one you recommended to me and the metal slope part does not cover that 4 inch overhang or the other one goes a little too far. It’s an awkward set up for sure.
Here is an area that looks like it may have had a liquid spill from the previous owners.
I remember ripping out the old carpet and finding the spot about six or seven years ago.
The rest of the floor looks like it’s in good condition but again I’m not sure. I’d love to start laying floor down now and not have to go by vapor barrier, but I would also like to do it correct if needed.
EDIT: just saw your response. I am on another slight hold this morning because I just found some low spots in this room with the hardwood that I need to patch. So frustrating because I had my planks laid out and was ready to start laying them down!
Thanks Joe!
What I will tell you is that if you are concerned, using Quietwalk LV would not hurt.
This may sound like a stupid question and I apologize, but would I lay the quiet walk LV down just over the old hardwood? Or over the entire layout with the new OSB as well? It’s 1.4mm thick so I’m not sure if that is thick enough to compromise the height difference going from the hardwood to the OSB when I lay the flooring.
OK, thank you Joe. Heading to Lowe’s to get some now. Here’s to getting this floor down this weekend lol
I’m not sure how to fix this.
I put down 3 boxes of Henry’s 549 in this spot alone today and layered it on thick. It is still incredibly off… very frustrating
To get an idea of what it looked like if the level was completely level (bubble in the center. )
Am I ok if there are no remarkable drop off or gaps still?
Should I not be concerned with the bubble being in the center of the level?
Sorry for the freak out posts yesterday, Joe! 😂
I’m on my way, laying down the Quietwalk LV and planks! I’ll keep you posted
So this is odd and frustrating.
I woke up to lay some more flooring and I noticed that several of my butt joints keep coming apart. I am making sure i am meticulous with each joint and making sure they are tight before moving on. But several have come apart. Any idea why?
I’m trying to bring it back together at the end of the wall but it is about 4 long planks away and not budging
Pics show what my tight joints look like vs the ones coming apart
