Activity Feed Forums General Newel Post
  • Newel Post
    Posted by Dennis on April 12, 2021 at 8:31 am
    Hi Joe – two questions for you:
    1) Can you share with me your thoughts about how I should approach installing my plank flooring around a newel post? Should I install with an expansion gap and cover with shoe moulding or undercut the post and install as if it were a door casing? See attached pictures.
    2) My staircase is in the middle of the room, and I need to install around it (as if it were a kitchen island). I snapped my reference line and have been verifying that both sides of the staircase are the same distance from the reference line, as you taught me. However, I am consistently 1/16 to 3/16 off in some areas. Is this going to be a problem when I join up the planks on the other side? If so, any ideas on how to fix it before i connect? I already have many, many rows of plank installed so it would not be terrific to rip the whole floor up.
    Joe replied 1 year, 11 months ago 2 Members · 3 Replies
  • 3 Replies
    April 12, 2021 at 8:50 am
  • Dennis
    April 12, 2021 at 10:37 am
    Thanks for the quick reply. I’ve attached a video that might help explain the issue.
    I’ll try the string method in a bit to find out if my reference line is out. But please let me know if I have a huge issue that I should correct before going further. Please let me know if this link works.
    https://youtu.be/FfaVyP7g9Ww
    April 12, 2021 at 10:57 am
