Build up floor or remove tile?
Hi @joeletendre and all, I’m planning to install laminate across the entire first floor of our home. Currently there is old laminate, carpet and tile. I would really like to lay the laminate over the tile to avoid having to demo the tile, but then I will be much higher in those areas (hallway, kitchen) than others e.g. that have carpet directly on the subfloor. Is it possible to get a good result by raising the subfloor up to the level of the tile, and if so what would you recommend (e.g. plywood), or might I be better off biting the bullet and demo’ing the tile floor? Thanks!
