Brown Blueprint Request
Hey Joe,
Greetings from the Twin Cities!
I will be installing CoreLuxe Ultra vinyl plank in my house. We have a split level house, and the plank will be installed in the entire upstairs, except in the kitchen and bathroom. I’ll also be installing it on both stair cases and in the entryway. I’ve attached a layout of our house so you can see what I’m working with.
I’ll be working with a wood subfloor in all areas except for the small landing at the bottom of the steps leading into the basement, which will be on concrete. But this area is small, probably 3×5 feet.
Upstairs I’m planning on no transitions between the rooms, and will use the hallway to line things up.
I was thinking of installing north to south, so I’d start by the bay window in the living room. That way I would only have to work backward in the master bedroom.
However I could also go the other direction, south to north, and then I’d be working backwards in the 2nd bedroom. Let me know which direction you think would be best.
Let me know if you need any other info, and thanks for your help!
