Blueprint Request
We are getting ready to install Lifeproof LVP and would love if you would help us with a blueprint. We have a few questions.
1. I’ve uploaded a floor plan, do you need measurements or will this work?
2. Our laundry room has already been done (had a flood and contractor installed) so we need to know if it’s best to use a transition or to try to remove the boards in the doorway and start from there. (See photo).
3. What is the best way to handle the stairs? We are using cap a tread and there is a significant difference in the height of the product compared to the LVP. Plus, I’m assuming we should run the floors the same direction as the laundry room which means the top step will but up against the “short end” of the LVP. Do we just use a reducer transition?
