Blueprint Request – Stefanie’s DIY
Hello Joe,
I’ve been working my way through your videos online – they’re so helpful and informative for this first-time DIY’er!
I am redoing the flooring on the first floor of my three story townhome – it’s about 400sf and is all on a concrete slab. Thus far I’ve been able to easily remove the carpet and with the help of a floor stripper, remove the linoleum from the bathroom; but I will need to hire a professional to get the glued down engineered hardwood from the last 200 sf. (I tried all day on Friday and lost the fight). I think it was installed with glue to withstand an apocalypse because after hours of work, I hadn’t made any progress.
I’m installing Pergo Timbercraft WetProtect + laminate over Pergo Gold underlayment. (Pictures of Pergo planks are attached).
I’d like to install the planks “east to west” or long ways down the hallway.
A few questions to start:
(1) In the bathroom, what should I use to fill in that hole next to the drain for the toilet? The linoleum was installed around the toilet (not under it) so I do not have any idea what to do.
(2) What do I do if I cannot get all the glue up out of the bathroom? I’m planning to get all of it removed; but what if there are any sections I cannot completely remove? I have Sentinel 747; but haven’t opened it yet so please let me know if there is something else you’d recommend.
(3) Can I use a mitre saw to cut the Pergo planks? (That’s what I have already). I also have a jigsaw and oscillating tool for cutting the more detailed sections and undercutting the doorframes, etc.
Thank you so much!
Stefanie
