Blueprint Request
I am ready to start the installation of my LVP. I have watched the videos on the Plank installation course, I would still like your input on where to start and a few areas of concern.
1) We’ve already spoke about a dip in the kitchen. With it being so severe you suggested I run the plank parallel with that dip. So I’m guessing that will determine the direction of the plank for upstairs & downstairs.
2) Upstairs in the hallway I have a closet with a small piece of flooring inside of it. I would need your help on how to scribe the plank / use a cheater board to install. ( image attached)
3) There will be a set of stairs I need to install planks. I believe we are waiting on a stair installation video. But in the mean time could you share with me any prep work that could be done on the stairs so they are ready for install ( image attached)
4) I plan to install the plank into each bedroom without transition strips. 1of3 bedrooms is facing a different way which would leave the ” butt ” joints landing in between the door jamb. Would this be ok ? I’m not sure if I’ve seen any videos with plank being installed this way between the door jamb ( image attached of hallway upstairs)
Let me know if there are any more pictures that I should share!
Thank you Joe,
