Blueprint and flooring info
Hello, I’ve attached the layout of the floor I’m going to be installing new vinyl plank flooring in.
Wanted to get your opinion on how I should start and lay it out.
I think I should start in the master bedroom and run it the length of the room. then into the hallway and transition into the other two bedrooms.
Thanks for the all the videos, they are great. I’ve don’t hardwood and laminate plank in the past but your videos have really helped with some of the more difficult parts of the process.
I’m looking forward to seeing how this turns out after having seen your process.
I did do the layout in metric, thought it might be a better way to approach the install after watching you make a cheat sheet…lol Let me know if you disagree.
Curtis Loper
