    December 24, 2021 at 6:39 am
    Here is a video I need you to watch – http://somup.com/crlZlg0Rsi
    • vidamj
      December 24, 2021 at 3:10 pm
      Hey Joe, thanks for the quick response.
      1. You are correct on the direction and starting room of the floor.
      2. Where you questioned if there was a door or if it was a wall in the north west corner of the living room that is a wall. On the other side of that (where I’d work backwards) as you said is the door to the garage and door down to the basement.
      3. As far as removing the particle board, to clarify, just remove it in the entire house and get down to the sheeting? I’m not concerned with the effort just doing it correctly as to not have problems down the road.
      This is actually at my dad’s house so I ran over quick and popped up a chunk of the particle board up on the living room side and also attached a picture of the planking. And yes I would love a layout plan that way I can just start snapping lines and get to work.
    December 27, 2021 at 9:22 am
    • vidamj
      January 3, 2022 at 6:53 pm
      I was actually wondering if you were going to suggest feathering out where the quarter inch was but I think what I’m going to is your second suggestion and take out the particle board in the living room and putdown new subfloor to match the rest of the house. I’ll then cut the green back and feather out that little bit there. I was just about to watch your blueprint and then all the kids came down. Hopefully I’ll get to that video later tonight or tomorrow. Thanks so much Joe.
    December 27, 2021 at 10:27 am
    Here is your blueprint – http://somup.com/crltDt0WIF
    January 4, 2022 at 8:32 am
    Sounds good Mike!
