Activity Feed › Forums › Floor Prep › Vapor barrier required on concrete floor if laminate contains a barrier? › Reply To: Vapor barrier required on concrete floor if laminate contains a barrier?
If you are willing to add the extra expense, I would suggest using quiet walk pad – https://amzn.to/3FE7ku4 . Otherwise, definitely use a vapor barrier.
