Activity Feed › Forums › Floor Prep › Vapor barrier required on concrete floor if laminate contains a barrier? › Reply To: Vapor barrier required on concrete floor if laminate contains a barrier?
Joe, thanks for the reply. The laminate is 12mm, and here are a couple pics of the locking system and the installed barrier.
Thoughts after seeing this? Thank you, Frank
