Thanks very much for the video Joe, it’s perfect!
What are your thoughts on securing the subfloor?
If we are installing 1/2 inch plywood on top of the current 3/4 inch tongue and groove subfloor? What is the best approach for installing the plywood?
For instance, do we use a two inch screw and first drive some screws into the tongue and groove subfloor along the joist every 8 inches to remove any squeaks? And then put the plywood on top and again run 2 inch screws along the joists?
Or do we secure the tongue and groove subfloor with 2 inch screws along the joists. But then use something like a 1 inch screw to attach the plywood to the subfloor. I thought I should use a 1 inch screw here because I was worried about the screws penetrating through the bottom of the tongue and groove subfloor. I guess it’s a matter of securing to the joist or the existing subfloor.
Also, should we use any glue/adhesive when attaching the plywood to the subfloor?
And the last question, when we attach the underlayment to the plywood, do we attach the underlayment to the plywood – and if so, should the underlayment be glued and stapled to the plywood? Again, assuming the staples would only be 1/4 inch so as not to penetrate the subfloor?
Thanks again!
