Activity Feed › Forums › Where should I start – Post drawings and questions › Time to get started › Reply To: Time to get started
Morning, Joe. Thanks for the blueprint. It’s a lot to absorb. I’m going to keep going over it till it all soaks in. Still working on floor prep but I thought I should give you this info on my hearth transition area so I’ll know how close to make the planks when I get started. Caulk or transition strips or…? Also, you say I should start with the angles. Should I leave off the first board and cut the angle last in case I have to adjust the 1st couple rows? Thanks, Joe. Have a blessed day! Mark
