Activity Feed › Forums › Where should I start – Post drawings and questions › Carlos’ first LVP project – upper floor › Reply To: Carlos’ first LVP project – upper floor
Hey Joe, I will start laying my planks this weekend.
The pad I’m using is from Roberts and the instructions say it best to leave extra 2″ all around the perimeter of the room that would go up and behind the baseboards. Do you think that’s necessary? I was planning on installing the pad flush to the walls.
Please also see attached pictures of the transitions between first room and bathroom. As I said before, I will leave the bathroom as is. There is a stone transition that I actually quite like it, but not sure if I’ll be able to use it after the LVP is installed. There’s currently an 1-1/8″ difference in height right now. I showed pics of two doors, one still has the stone transition and the other door, it has come off.
