Activity Feed › Forums › Where should I start – Post drawings and questions › Blueprint Request pwyu1969 › Reply To: Blueprint Request pwyu1969
Thanks Joe. Two quick questions, for the closest bifold door bracket, can I just screw that down thus pinning the floating floor at that point, or is there something I should do to allow the floor to still move at that point? Also for the bathroom sink, I can either cut around it or lift it out and run the board under. (1) how should I cut around it, and (2) is it better to just lift the sink out, install floor, and put sink back. If so, doesn’t bolting it down pin the floating floor at that point?
Paul
