  • Paul
    May 5, 2023 at 11:26 am
    Working on floor prep. I have a few questions:
    1. You can see the contact cement from linoleum. Heat gun lifted it fine, but its quite sticky. Should I roll some kind of material, painters paper, aluminum foil, etc… over it keep LVP from sticking?
    2. Other than scraping up drywall mud, feather goop fill gaps and low spots in floor, anything I should be concerned about with the type of material for the subfloor or prep?
    3. I cant see if the sub floor is screwed down anywhere. Could it be floating too? Should I screw it down? Seems solid enough.
    Paul
