Activity Feed › Forums › Where should I start – Post drawings and questions › Ready for a screencast. Picture uploaded. › Reply To: Ready for a screencast. Picture uploaded.
Thank you. That’s a lot to digest. I appreciate the time and detailed explanation. We had a little set back, as the baseboard will be closer to the floor on reinstallation and had to remove/patch the raised paint line on the wall where the top of the baseboard met the wall. Decided on new paint for the walls before the floor install.
A question popped into my head while taping off the trim. It appears the undercutting I did for our current laminate floor will leave a small gap since the LVP is thinner. If it’s noticeable, can I put a thin bead of caulk in the gap and finger it smooth?
Thanks again,
Danny
