Activity Feed › Forums › General › Kitchen Obstacles › Reply To: Kitchen Obstacles
Both of those should be moved up. Either the toe kick will need to be modified or the vent and the central vac will need to be modified if the toe kick is not the answer. Can you share a pic under the toe kick showing the top of each of those?
