Activity Feed › Forums › Where should I start – Post drawings and questions › Smart Draw › Reply To: Smart Draw
The floor’s had laminate planks originally, so the lvp will fit under the hearth. I didn’t draw the front windows correctly. There is no space at the window, it should be a wall line. I like the north and south plank direction. Next week is fine for the blueprint, I still have to replace some of the 3/4 inch plywood floor in the living room. Thank you for the info on the overlapping stair nose.
I was looking at stair nose for laminate.
Thank you,
Mike
