Activity Feed › Forums › Floor Prep › Build up Subfloor to Match ex. Hardwood Floor Height – Oli and Summer › Reply To: Build up Subfloor to Match ex. Hardwood Floor Height – Oli and Summer
Hello Joe,
Hope you are enjoying the family hunting weekend! We have finished adding the 23/32″ OSB underlayment for the whole 1st floor. Thank you again for all the tips!
We have the crawl space access hatch door right in the middle of the utility closet (see the attached photo). We are considering gluing down LVP planks on the perimeter + hatch door as well as having a T-molding transition at the closet door.
- What type/brand of adhesive is recommended for gluing down multiple planks? We are planning to glue down LVP on the transition areas of stairs as well (see the attached photo).
- This closet has a bifold door and its bottom bracket is usually mounted to the floor and the door jamb (see the attached photo). How should we install this bottom bracket with the floating LVP floor?
Thank you very much!!!
Oli and Summer
