Activity Feed › Forums › Where should I start – Post drawings and questions › Where do I start? › Reply To: Where do I start?
I would not worry about sliding the plank under the trim if you are using quarter round to cover it. The only places you would need to run under the trim a little bit would be around the door jambs. I like to go under the trim past the doorjamb casings at least 2 inches so the gap won’t show at the edge of the quarter round. Make sense?
