  • Posted by Peter on May 24, 2021 at 3:33 pm
    Hi Joe – I have a small basement layout attached. There are two rooms plus a small laundry room. I’m laying vinyl plank on concrete floor. Room 1 and Room 2 are connected via a pocket door that is left pushed into the wall.
    Joe replied 3 years, 8 months ago 2 Members · 11 Replies
  • 11 Replies
  • Peter
    May 24, 2021 at 3:46 pm
    drawing
    May 24, 2021 at 4:01 pm
    For some reason your drawing did not upload
    • Peter
      May 24, 2021 at 4:20 pm
      I have no idea why. Let me try again
  • Peter
    May 24, 2021 at 6:53 pm
    May 25, 2021 at 11:08 am
    Can you answer a couple questions for me – http://somup.com/crhTDiqX0u
    • Peter
      May 25, 2021 at 11:37 am
      HI Joe – Thank you so much for the video. I feel like we are friends – Great!
      1. You are correct – that door is the backside of laundry room (the HVAC, water heater) sit there. I will be flooring the laundry room but will end the floor on a line before all the HVAC equipment. I’m guessing a simple transition strip or something glued over the edge there.
      2. I’m thinking North to South – however I yield to your advice.
      3. I picked an American product called Rokplank: its an SPC (Stone Polymer Composite) Rigid Core, Waterproof – Drop-Lock plank:
      My 10 board measurement: 71 7/16, (20) 142 7/8, (30) 214 5/16, (40) 285 3/4, (50) 357 3/16
      Questions:
      1) I didn’t see the glue stick from one of your videos on your tool section. I’m on concrete and will need to glue down the pieces to hold the first 4 rows. You also showed drilling with a hammer drill 3/8 bit and using a certain type of screw ?con -something.. I can do either
      for the stairs a I made a jig from a 4×4 and took 1/2 the thickness of the backside of the board with a hand router and heated the plank with a heat gun and formed a perfect bullnose.
    May 25, 2021 at 3:29 pm
    • Peter
      May 25, 2021 at 4:10 pm
      Thank you sir! yes the router and heat gun trick is nice but it does take some time per step.
    May 26, 2021 at 12:20 pm
    HERE IS YOUR BLUEPRINT – http://somup.com/crhObqqIug
    • Peter
      May 30, 2021 at 12:48 am
      Joe –
      Project is moving along nicely. Not without the usual rookie mistakes. The 10 plank template was a complete life saver. I was able to measure all the rooms from my original line to determine how much space my last rows gave me. I only had one small wall where I only had about 2.5″, but the super glue trick was brilliant. I think we are going to put a transition in the laundry room and figure what to do there at the end. Probably will have a question regarding the T mold for the bathroom entry. I’ll need to shoot you a picture of my TMold and the marble transition that was already there to have you provide some guidance. Anyway, here are a few pics of my work in progress. My wife and I have been watching your videos every night. Oh, I used the Tapcon screws to start the job because the glue took forever to come in from Amazon. It came in and used it for my other starter rows – It’s amazing and so much faster and easier on my concrete floor than running my hammer drill like a mad man.
      Thank you for being awesome!
    May 30, 2021 at 10:53 am
    Wow buddy you guys are killing it looks great!
