Activity Feed Forums Bootcamp Corner – Weekly Calls My new project layout
  • My new project layout
    Posted by cbokoski on June 22, 2024 at 2:29 pm
    My last project we did not have stairs, fireplace, or but up to cabinets
    Attached is my layout, we plan on doing everything but the master bath
    The current entry is 3×3 tile we have to remove and the bathroom is tile we will remove
    The kitchen has an old skinny wood floor to remove
    I will need to stage install as a newborn baby will be joining us durning this adventure.
    I know bad timing, but we need to get flooring done.
    We had someone quote the project and they had 3 stripes of bullnose for the finished basement stairs. They also quoted 3 endcaps Which I wasn’t sure where they would be used except for stairway board
    Layout (photo 1)
    What is the blueprint I have seen, is that something you can send out?
    Question: do I need flush bullnose for the stairs and for the top of stairs? I have seen overlay bullnose, and didn’t really like that look but are they needed at the top of stairs
    Question: do I use endcaps by fireplace (photo 2) or any area that does not have trim
    Question: Do I use the end-caps along the stair railing (photo 3)
    Question: Do you usually remove cabinet toe-kick and put LVP under it?
    Question: do you need quarter round to butt up to kitchen cabinets?
    Joe replied 1 week, 1 day ago 2 Members · 55 Replies
  • 55 Replies
  • cbokoski
    June 23, 2024 at 9:55 am
    Adding to my post did the smartdraw, but they no longer let you export unless you purchase
    so this was just a screen shot. Also I will be using Mannington AuraMax planks
    June 24, 2024 at 9:41 am
    • cbokoski
      June 25, 2024 at 8:16 pm
      Thanks Joe, read your reply, that all made sense.
      Here were a few of the pictures. the stairs, fireplace.
      Watched all you Boot camp videos, it really helped me with going up to the tub.
      I didnt see much there on stairs or endcaps, so I will look through your other videos, so see if I can find stair/endcap installations.
      Also went to a friends to check out their stairway and they did a small
      quarter round instead of endcap, is one better than the other?
      Pic 1: basement stairway ( deciding if I should do LVP or carpet)
      Pic 2,3: fireplace ( sorry they took this with the screen in front, I am not at that location currently) but the 2nd pic shows it closers, it has the access door open.
      Pic 4: shows the stair rail
      Pic 5: shows my fiends completed stairs-looks like a small quarter round (if thats possible)
    • cbokoski
      June 25, 2024 at 8:31 pm
      We are doing the whole house except for the master bath as they have a heated floor in there.
      Plan is to run planks east and west from the front door to the back
    June 26, 2024 at 7:17 am
    • cbokoski
      June 27, 2024 at 1:58 pm
      One more question, In the master bath, they have a wood or lvp floor that is heated.
      Wondering if I should remove the flooring or just go up to the current floor with lvp.
      then what type of transition would I use. I am working on getting a picture of the area.
      and will post that as soon as I get one. I will not know if they are exactly flush with eachother
      until the flooring is delivered
  • cbokoski
    June 26, 2024 at 11:04 am
    Thanks Joe for your help.
    Will be checking out your suggested videos today
    June 27, 2024 at 2:09 pm
  • cbokoski
    July 9, 2024 at 9:47 am
    Do you have recommendation on the best way to remove trim. Mainly the caulk. I have been using a utulity knife, just wondering if the was any better tool
    July 9, 2024 at 1:49 pm
    Yhe caulk needs to be cut with a utility knife.
  • cbokoski
    July 12, 2024 at 11:07 pm
    Going to put carpet on basement stairs, LVP on landing, do we install the overlapping bullnose
    First and install carpet afterwards, or carpet first
    July 13, 2024 at 10:32 am
    • cbokoski
      July 15, 2024 at 12:46 am
      I can use a flush bullnose even if it’s not a small landing but right into family room like original hand drawing? Flooring direction From front door to back, so short edges at top of stairs
      Other question, looking for the stand up staple remover, does it have wheels on it? What exactly it it called. Looking to see where to get one or if I can rent one..
      Is it a smooth edge or like a zig zag edge. And is there wheels on it?
      Thanks again
      • This reply was modified 3 months ago by  cbokoski.
    • cbokoski
      July 15, 2024 at 1:00 am
      I can use a flush bullnose as you stated for carpeted basement. Stairs even if it’s not a small landing but right into family room like original hand drawing? Flooring direction From front door (east to west)
      Thanks again
      • This reply was modified 3 months ago by  cbokoski. Reason: Reply to wrong person
    • cbokoski
      July 15, 2024 at 1:13 am
      I can use a flush bullnose as you stated for carpeted basement Stairs even if it’s not a small landing but right into family room like original hand drawing? Flooring direction From front door (east to west) per hand drawing
    • cbokoski
      July 15, 2024 at 1:18 am
      I can use a flush bullnose even if it’s not a small landing but right into family room like original hand drawing? Flooring direction From front door to back, so short edges at top of stairs<div>
      </div><div>Sorry if you got this a couple times, I tried to edit and it was keeping old versions</div>
    July 15, 2024 at 7:58 am
    Wait. Share a pic of the landing. If you are saying the landing is the main area of your floor, then NO, use an overlapping stair nose. What staples are you referring to? A stand up scraper will remove staples that held the pad on the floor. It does not have wheels. It can be purchased from home depot.
    https://www.homedepot.com/p/Bon-Tool-8-in-Razor-Floor-Scraper-14-712/301960100?source=shoppingads&locale=en-US&srsltid=AfmBOor9jqAMGYhZ4jgQUKonP6Z6JFlphxqdrlESl4ShD7ZFKMS5JQwJJjc
    • cbokoski
      July 23, 2024 at 12:33 pm
      Here is the top of basement stairs
      Also, I have a heated floor in bathroom. That I am thinking of putting my new LVP in would I need a transition or is the heated floor thin enough I can just keep running my panel straight across non heat to heated area
      Pic 1 basement floor
      Pic 2 carpet to current heated wood floor. Would like to make it all one floor
    • cbokoski
      July 23, 2024 at 12:55 pm
      We have a walkway where wall to wall we have 53 1/2”
      And wall to stairway 50”
      Trying to figure out which area we should center planks
      Or should we install plank in the other direction
    July 24, 2024 at 8:27 am
    • cbokoski
      August 17, 2024 at 10:31 pm
      Floor prep
      Installing Audra max
      Finally got to location and working on floor prep. Our centerline in hallway seems high and that the side slope down. Like a teeter-tauter Watched your large dip and Floor prep and small dip videos
      It is about a 1/2” dip if I hold the right side on the floor if I center the bubble I get about 3/8” on each side
      What’s my best option to correct?
      It is wise in the hallway and still get a little ricing in the dinning room on that center seam
    August 19, 2024 at 8:32 am
    Share a pic of where this is at. I am not sure on your drawing where it is at.
    • cbokoski
      August 19, 2024 at 9:15 am
      The worse part is in the little hallway, by laundry and bathroom. we did find out it is perpendicular to the floor joist. We cut part out and planed a high joist, which helped, But not sure if we wanted to cut out the whole floor. The part that is not real bad is in the dinning room
    August 19, 2024 at 9:40 am
    • cbokoski
      August 20, 2024 at 8:50 am
      We are planning on laying LVP across floor perpendicular to hall.
      Thinking of cutting out about 15” all they way across house
      With 5/8” plywood and the fill with Ardex, but wondering if floor will feel weak without the 3/4” wood
    August 21, 2024 at 8:13 am
    It should be ok.
    • cbokoski
      August 27, 2024 at 11:13 am
      Using Ardex when mixed according to package it seems a lot thicker then when I watch you do it. Should I add more water? Seemed pretty thick to move around
    August 27, 2024 at 5:26 pm
    add more water. I don’t go by what the bag says.
    • cbokoski
      August 29, 2024 at 7:49 am
      We still have a few peaks after redoing some of the subfloor. You mentioned tar paper once just wondering if u have a video or instructions on that.
      We have added a joist between every
      Floor joist and plywood glued and screwed, but a few places I stil have a little edge I feel
    • cbokoski
      September 5, 2024 at 8:50 am
      Is there a tool to undercut metal corners. All our outside wall corners are rounded with metal. Would love to undercut. Especially by closet doors
        September 5, 2024 at 9:27 am
        • cbokoski
          September 5, 2024 at 3:45 pm
          Thanks for info. One more question.
          Any trick to mark an alcove, wall seem to be at a 45 degree angle.
        • cbokoski
          September 6, 2024 at 7:10 pm
          Great to explanation and video game of the angle cuts
          When putting on trim and you see a slight floor dip, so trim sits up a little bit, can anything be done?
          Do you leave it or caulk it?
Page 1 of 2
