  • Posted by Scott on April 6, 2022 at 4:59 pm
    Hello Joe:
    Attached is the rough floor plan of the house,… Taking in everything you have said in the videos, I am considering starting at the foyer/living room running the laminate east to west…
    My goal will be to reach the kitchen,dining & breakfast room (kdb room) and have a straight run into the doorway labeled as “to den”.
    From watching your videos, starting in the foyer/LR gives me the straightest wall and I can measure out the line that will run from the kdb room into the den.
    One consideration I have; the hallway is roughly 42″ wide and my planks are about 48? I assume I should break up the hallway planks and not just lay them down one after another.
    Enclosed is the pdf.
    Thoughts??
    Joe replied 11 months, 2 weeks ago 2 Members · 11 Replies
  • 11 Replies
    April 7, 2022 at 5:39 am
  • Scott
    April 7, 2022 at 12:31 pm
    I went back and cleaned up the drawing a bit… I also measured out 10 planks and they are 61 3/8″
    Hope this answers a few questions.
  • Scott
    April 7, 2022 at 12:51 pm
    Hello Joe:
    I also sent you an invite for an apple link to some pictures and video of the upcoming job.
    April 7, 2022 at 12:55 pm
    I am not seeing anything that you posted, did you watch my video I sent?
  • Scott
    April 7, 2022 at 1:34 pm
    That is interesting. Yes, I watched the video.. Very helpful… I sent a link to some videos… I also went through the steps to upload a new drawing…. Not sure why it did not upload…. I resent the link to you…
    April 7, 2022 at 2:00 pm
    I really am not sure why the link is not showing, but here is my email if you could send it there – floormechanics@gmail.com
    • Scott
      April 8, 2022 at 9:48 am
      Hello Joe:
      I show the updated drawing sent to you above at 4/7 1334 et. Regarding the pictures and links, I sent those to you via the email you provided… Were you able to receive those pictures via email?
      As I said in an earlier post, I did watch your video and I returned the drawing and pictures that show the kitchen cabinets and the additional den. Except for the garage, the whole floor area is to be planked.
    April 8, 2022 at 11:10 am
    Got everything Scott and I will get on this today.
    April 8, 2022 at 4:32 pm
    Here is your blueprint – http://somup.com/c3fjrwOoVN
  • Scott
    April 10, 2022 at 2:57 pm
    Hello Joe:
    I watched the video… makes sense… thanks for taking time to put it together… I did have two new questions.
    1) You asked if I was going to use additional padding… The product has a pad on it… I thought uses 2x padding caused issues?
    2) I have a upward bow in the kitchen floor, which runs perpendicular from the sink out into the the floor area… It is about 1/2″ and you can notice it when you walk in front of the sink.
    Previously we had a nail down engineered oak floor and the nails held the the flooring to the subfloor… My research says to cut out a portion of the 4×8 subfloor and then plane the joist down and then fasten sister joists along side and reattach the cut out section… I have a power plane. I needed that to make sure my studs were plumb in the bathroom tile job…
    Scott
    April 11, 2022 at 5:15 am
