Activity Feed Forums Floor Prep Linoleum question
  • Linoleum question
    Posted by Rick on October 11, 2021 at 9:32 am
    I have a question regarding running over the linoleum in my kitchen, laundry room and bathrooms. The linoleum is 1.03 mm (I measured a strip I cut back with calipers). Should I use Henry’s and feather it a foot or so on the slab or do I just run over it? To refresh the laminate is 12 mm including the 2 mm built in underlayment. I ran plank up to the linoleum and the linoleum falls in the joint the entire length in the kitchen pics (so it’s that space where there is no underpayment under the planks).
    Also in the bathrooms and laundry room the linoleum runs under the door jambs, should I cut that out and start the linoleum away from the door jamb?
    Rick
    Joe replied 1 year, 5 months ago 2 Members · 4 Replies
  • 4 Replies
