Let’s get started!
Hi Joe! I have purchased my first home and have BIG plans for it… not too big, I hope! I have leased it back to the previous owners until the beginning of June, so I am trying to do all of the planning for my projects now. I am planning to replace all of the floors with vinyl plank. Currently, there is carpet, tile, and sheet vinyl throughout the house (see the demo plan I provided). I will be replacing the baseboards after doing the floors. The sliding glass patio door will also be replaced with french doors. My plan is to do that before installing the floors, but you may know what timing would be best.
I have narrowed down which plank I will be using to the following 3:
1) Smartcore Ultra XL – 8.97″ x 72.04″ plank size with a 12 mil wear layer
2) Smartcore Pro – 7.08″ x 48.03″ plank size with a 20 mil wear layer
3) Lifeproof – 7.5″ x 48″ plank size with a 6 mil wear layer
Have you worked with these? What are your opinions on the plank size and the wear layer? I know 20 mil is a little bit overkill, but what about 12 mil? I’m really hoping you can point me in the right direction!
I have included my floor plan. Can you give me an idea of which way you would run the planks and where I should start? ANY ideas or words of caution are welcome at this point! I do have access to the house, but I’m trying not to bug the tenants too much! Are there a few key measurements that you could use to get us going?
Thank you so much for your help!
