Is Linoleum Removal Necessary
Hello,
I have linoleum installed in my kitchen. I will be removing all carpet in surrounding areas. Should I also remove the linoleum? It was just installed a few weeks ago. Or would you recommend just installing over the linoleum and using a floor leveler where it meets the concrete subfloor so there is a seem-less transition from concrete to linoleum under the vinyl plank. This is the only picture I have at the moment.
Sorry, there were no replies found.
