Installation Blueprint
Here is what I am installing:
CoreLuxe Engineered Vinyl Plank (EVP) 8mm Oyster Shell Travertine Rigid Vinyl Plank Flooring
Width: 12 in. Maximum Plank Length: 24.016 in.
Underlayment: Dream Home 6mil Poly Sheeting
Installing on top of concreate slab. I was able to level the floor to under 1/8. I am installing in my living room, dining room, kitchen and hallway.
My thought is to start the installation in the SW corner by the garage door and run it North to south. In the diagram I laid 1 ft lines in red in the diagram to simulate the planks. I have 2 options – start with a full plank or start with a 6″ plank.
My hallway is 3 ft. 6 in. wide and it looks based on measurements that it will center with 3 planks and 3 inches on either side. I know that you would prefer to have it centered with 2 full planks and 9” on either side but that means that I would have to start with a 6 inch plank instead of a full plank. Not a big deal but I will have to cut an additional 15 planks in half (more work.) It will also leave a plank less than 4 inch at the kitchen (but to be honest no one will ever see that plank.)
Any advice for how to do this would be greatly appreciated!
Let me know if you need any more information.
