Activity Feed › Forums › Where should I start – Post drawings and questions › I have uploaded my floorplan – How do I get the blueprint?
Posted by Jack on May 10, 2021 at 5:02 amJoe, Just joined the site. I have uploaded my floorplan. How do I obtain the blueprint? Of course, I plan on running the floor through the hallway on the longest section of the basement. I really need the start points and how to get through the one opening to the media room without using a transition piece.
Thanks for all your help.
Joe replied 3 years, 7 months ago 2 Members · 20 Replies -
Joe, thanks for the fast action on this project. To answer your questions:
1. Yes, I want to run the floor East & West. The basement has a walk out door and windows on the east side and that’s where the light shines in. As soon as you walk down to the basement from the first floor you’re in the hallway of the bar area and you can see all the way through the basement to the end of the guest bedroom.
2. I believe that hallway is where I would place my reference line. Is that correct?
3. Mu biggest question is how do you work back to the reference line with accuracy from the other side of the room?
4. Just for your information I am using Lifeproof Flooring from Home Depot. It has 3 different board widths in the box that I will be able to mix throughout the floor.
5. I have purchased transitions for the entry doorways to meet the thresholds. Do I really need them?
Thanks so much for your time on this.
Additional Comment:
The floor is concrete, I have not installed the doors and trim yet. I installed the cabinets with space to slide the flooring under the edges and then put trim over to avoid quarter-round molding, which I hate.
I posted a couple of photos of the planks. They are all the same length with three different widths. The two smaller boards equal the width of the largest board
I viewed the profile the day you posted it, but late at night. I understand everything so far. I just hope when I get through the door in the middle that I can keep it straight on the other side. I’m positive I can snap a straight line in the first room according to the blueprint, but I’m not sure how to make sure it is parallel to the line going through the hallway. Is there any tolerance with adjusting the boards to the line after going through the doorway to the second room?
Joe, here are some pictures of the doorways. The doorway to the staircase has an exterior threshold. Can I take this out? The only other doorway that I don’t know what to do is the bathroom with the tile “shluter “ piece installed. The others all go to the unfinished workshop which I will just end at the doorway without a transition piece
You can take the threshold out but it will no longer be a sealed door and you might have some painting to do.
You can use a t molding at the schluter and just cover it.
I hit the prime reference line in the hallway last night and I’m no more than 1/8 in off all the way down the hallway. Thanks for the blueprint and all the coaching so far. I’m approaching the cabinets in the bar area and I installed them with clearance to slide the flooring under the edge of the cabinets. Any tips on getting the flooring under the cabinets? I tried to upload a video, but it won’t let me. I’ll send a photo later.
Here is my email if that will be easier or you can send that to my phone-
(218) 256-8080
