Activity Feed Forums General Gorilla Glue Technique
  • Gorilla Glue Technique
    Posted by jlayne1971 on June 20, 2022 at 7:38 am
    Hello again, Joe,
    I am working my way down a hallway with multiple doors. In my case, the planks needed to run perpendicular to the doors, and I had to use your technique of shaving down the lip on the female edge and gluing the planks together so that I could slide them under the door casings and jambs. As you can see from the pic, there are several areas where I had to do this which are taped together while the glue sets. Should this hold, or do I need to worry about overusing the technique? Thanks. Jay
    Joe replied 9 months, 2 weeks ago 2 Members · 1 Reply
  • 1 Reply
    June 20, 2022 at 9:41 am
    No, you can keep going and you can use this method as much as needed.
