Posted by informatics on October 1, 2022 at 9:41 am
Had our lvp done in the kitchen “professionally”… one of the many problems I’ve had is there is one section where the seam is not quite together in the but joint. I’ve tried using double sided tape, taped to a board, and tapping it in but no go. Can I do anything here?
This Was about 2 1/2 feet from a door transition that I need to change out anyways due to the poor job done by our contracted work. This worked like a charm! Thank you!
