Floor Prep Flatness and Blueprint Request
The area that I am working on is the basement of my house. The floor is concrete and is approaching twenty years old. It was previously carpeted. The carpeting has been removed, the entire concrete floor has been cleaned with a floor grinder. There are only two cracks which are mostly 1/8”. It looks in wonderful condition…until you put a level on it!
I would describe it as mostly two level planes with a ½” difference in elevation. The transition zone can be as short as two feet across as the floor raises/lowers ½”. There are several places where the concrete is slightly wavy in elevation with maybe a 1/8” variance in height and two or three feet between the crests/valleys.
There are also two ½” mounds in addition to the larger planes described above. Both of these mounds have been ground down about halfway by using a floor grinder. (sidenote: painfully slow!)
The plan is to install LVP. While we are open to other suggestions, we are currently leaning towards Flooret’s Modin Signature LVP. It is sized at 9 inches by 6 feet. A picture of a sample piece is included so you can identify what you need to know about it. It would be my preference to install the entire floor without any transitions. LVP flooring is to be installed in all rooms in the drawing. This includes the main L shaped room and both bedrooms with their closets.
There are several items on my wish list:
#1 Guidance on flattening the floor. My perfectionistic nature would like to see the entire floor perfectly level and flat. I understand that unless I want to grind the floor for another six months that is not realistic. I do NOT want to raise the flooring for the northern three doors (tiled bathroom, epoxy floor closet and bare concrete furnace room). The northern end (with the wavy orange lines in my elevation drawing) probably needs Henry’s 549 screeded across it. Simple enough. I started grinding down the two ½” tall mounds in the middle of both legs of the L room. The ½” elevation change transitions between the different planes has no good solution that I can figure. I am trying to achieve the balance between properly supporting the LVP so it will last a long time and looks/feels good while keeping the prep time realistic. How do I properly prep the floor for flatness at the ½” elevation changes between the planes?
#2 Can you expound on what 3/8” variation in 10 feet means in real life? (this is the real question behind the first question) If this 3/8” variation was evenly distributed across the 10 feet then it would just be another flat plane which existed at a slight angle. I would guess the opposite, being a 3/8” instant elevation change like a stair step, would be completely unacceptable. It seems like the relevant issue is the deflection point and how abrupt the elevation or angle changes combined with the height difference. Or maybe how wide of an unsupported distance combined with the depth of the valley. Sorry to describe it so poorly. What is real world “good enough” flatness to properly support LVP?
#3 Recommendation on direction to run the LVP planks, where to start the starter plank and your general advice/blue print.
Thank you very much for the service you provide. Your expertise and advice are very appreciated! Please let me know if you need any additional information.
God bless!
Quinn
