Activity Feed Forums Where should I start – Post drawings and questions Floor plan – Need help starting point
  • Be
    June 15, 2021 at 1:43 am
    Hi Joe, also we decided to run the floors horizontal, south to north
    June 15, 2021 at 7:41 am
    Watch this and please answer the questions I have for you – http://somup.com/cr1olpqkPs
    • Be
      June 15, 2021 at 8:00 pm
      Thank you for the reply! I have attached the photos for you.
    June 16, 2021 at 8:19 am
    Thanks Be! I will get this done today.
    June 16, 2021 at 11:51 am
    Here is your blueprint Be – http://somup.com/cr1DDKqCSp
    • Be
      June 16, 2021 at 12:35 pm
      Every time I try clicking it, it says upload failed. I tried on my home computer and phone, none is working. Is there another way I can view it?
    June 16, 2021 at 2:25 pm
    I am re recording this because of a technical difficulty, I will re post the link when it is done. About an hour and 15 minutes.
    June 16, 2021 at 4:34 pm
    I had to re shoot the entire video, but here you go brother – http://somup.com/cr1Dryq5qk
    • Be
      June 21, 2021 at 6:14 pm
      Hi Joe, thanks a bunch for the video! I got really excited to start and messed up below a door jam. I forgot to undercut the door jam and slide the board under. In my head I thought it was a regular wall where I had to leave an an expansion gap.
      I’m not sure what is the best route for this, should I take up that section and redo it, or is there a way to remove/repair it without taking up the 3 boards? Worried about taking it up since the board against the wall has a long but thin strip, and i’ll have to work backwards on that portion.
      Thank you in advance for your help!
    June 22, 2021 at 8:21 am
