Electrical outlet in middle of great room
Joe, working on last room. Have an electrical outlet in the middle of the floor that is going to stick up higher than the laminate. The outlet sticks up 1/2″ above the laminate. Looks like 1/4″ PVC coming thru the slab with 2 electrical outlet boxes stacked. I am sure they are glued together and glued to the PVC because they feel solid, no movement. I could cut off 1/2″ off the outlet box that sticks up, but that would cut off the top of the outlet box with the screw holes that are needed to hold the round brass cover. I might be able to cut off 1/2″ of the PVC and cut out the top outlet box from inside the PVC and install a shorter outlet box. See attached. The electrical wire is coming into the 1st outlet box and upward to the receptacle. Maybe you run into this before. Thanks for you help.
