Activity Feed Forums Floor Prep Do I need to remove these staples
  • Do I need to remove these staples
    Posted by tifftgannon on December 18, 2021 at 6:31 pm
    The prior owner had a linoleum or vinyl floor installed at one point that was replaced with engineered wood. I am now replacing the engineered wood with Mannington Adura Rigid 5.5 mm LVP. The contractor that replaced the linoleum with engineered wood ripped up the underlayment and then pounded the staples into the OSB. I’ve removed all the staples that stick out but wonder if I need to remove the ones that were pounded into the OSB. There’s probably ~1000 in there so would take days on my hands and knees. Am ok just putting the Adura Rigid right on top of them if they are flush with the surface of the OSB? Pictures with penny for scale.
    wcurtispreston replied 11 months, 2 weeks ago 4 Members · 5 Replies
  • 5 Replies
    December 19, 2021 at 7:41 am
    Those can stay.
    • tifftgannon
      December 19, 2021 at 10:25 am
      This might be the best news I’ve heard in a long time……..
  • shannon
    April 19, 2022 at 4:51 pm
    Joe I have this same issue but not all of them are flush. If I run a shovel over them it gets stuck in some places but they don’t go any deeper (promise I’ve hammered for a long time. ) how flush do they need to be? Should I try to cut all of them with oscillating saw?
    April 19, 2022 at 5:43 pm
    You should be good to go Shannon.
