Activity Feed › Forums › Where should I start – Post drawings and questions › Derek’s Blueprint
Hey Joe
I got everything back together with no gaps!! Woo Hoo! Now, I’m moving into the bathroom off the hallway. Question – do I need to put any Henrys feather over this tile to even out the grout lines so they don’t bleed through? I’m using Quiet Walk pad everywhere, so I wasn’t sure if I need the put leveler out as well. Thanks in advance!
Awesome brother!!!! That must feel good. No extra prep needed on the tile.
Hey Joe,
I hope this finds you well. I took a bit of a hiatus from installing flooring and I’m back at it now. The majority of the downstairs is complete and I find myself at some stairs.
I had originally wanted to warm up and bend plans to come around the front of the stair nose (as they are round), but I don’t have enough plank to clear the front of the nose.
I’m hoping you can give me some advice on how to proceed.
Should I remove the round tread and replace it with a square tread to be able to floor it?
I’ve attached a few pictures of those treads so you can see what I’m working with.
BTW – is this the best place to continue to post questions?
I thought I’d add a few other pictures of some of the stairs I successfully completed along with one’s I haven’t yet. These are located on my main staircase, whereas the previous post is a smaller 3 step staircase in another room. I would ultimately love to complete them all this way if possible.
