Activity Feed Forums Where should I start – Post drawings and questions Carlos’ first LVP project – upper floor
  • Carlos
    May 27, 2024 at 11:58 am
    Joe, besides de starting point for the LVP, I’ll have several other questions. Should I post them here too?
      May 28, 2024 at 10:27 am
      yes, post them here.
    May 28, 2024 at 10:33 am
  • Carlos
    May 28, 2024 at 10:12 pm
    HI Joe, thanks for replying. Yes, I agree with the starting point being Bedroom #1 (upper left corner of my floorplan). I draw some planks in that room just to show you the direction I wanted them to be. I’m ready to start. I have several questions, I will list them below:
    01. Measurements were taken wall to wall. Do you need me to take from the framing? The house currently has no baseboards.
    02. I’ll be using underlayment. Should I put underlayment in the whole floor first? Or as I go?
    03. Do you need me to post the width of 10 planks as you showed in one of your videos? I will be using LIFEPROOF, I will take a picture of the four sides and post them here.
    04. Are stairs a separate job or do I have to do them in sequence? Once I finish the upper fllor, can I move to the next and do the stairs at the end?
    05. What tools will I need? I understand I will need a tapping block and a pull bar, I’d appreciate if you could provide a few links. Or should I just go ahead and purchase the ones you recommend in your website?
    Thanks. Can’t wait to start. Please let me know if you need any additional info.
    May 29, 2024 at 10:28 am
    • Carlos
      May 29, 2024 at 1:16 pm
      Hi Joe, thanks for the great video. I watched it, but I’ll watch it again. There’s a lot of information there.
      I already have most of the tools, like the oscillating tool, utility knifes, knee pads and everything. I will buy the spacers you recommended and the tapping block. I have a hammer, will send you a picture for you to see if that’s ok for this kind of job.
      I will watch the videos you recommended and I am sure more questions will come once I start.
      One thing I did not share is that I’ll be working alone.
      You mentioned I can use an utility knife or a jigsaw to cut the planks. Can I use a miter saw to cut the planks? Or is it not practical?
      Thanks again.
    • Carlos
      June 1, 2024 at 6:16 am
      Hey Joe, I watched this video a couple of times now while waiting for all my tools to arrive. Still a few questions:
      01. In your recording at 14:14, in which video you show how to put the scrap pieces? I know that you usually screw them to the subflooring. In my case, I’d just screw thru the pad, right?
      02. TImeline 18:30 in the recording. It is probably a silly question, but why do I need this hallway line once I have already started and I am almost halfway through?
      03. Once I get to the point shown in 17:11 and the yellow circle that you pointed out, can I still mess up the alignment?
      Thanks
    here is a great video to watch that is using a plank with the same locking system as yours – https://youtu.be/4Gy_f0uPow8
    May 29, 2024 at 3:15 pm
    yes, a miter saw is perfect
  • Carlos
    May 29, 2024 at 11:08 pm
    Hey Joe, I took pictures of my plank and it looks like the configuration is like this. Am I right?
  • Carlos
    May 30, 2024 at 12:13 am
    Joe, I use Sketchup to draw my floorplan and I can simulate on computer where to snap the hallway line before snapping the actual line. Center line does not work as it leaves a little over an inch on each side. I measured the width of up to 10 planks. Here it is:
    1 plank – 8 5/8″
    2 planks -17 5/8″
    3- 26″
    4- 34 5/8″
    5- 43 5/16″
    6- 52″
    7- 60 3/4″
    8- 69 3/8″
    9- 78 1/16″
    10- 86 3/4″
    The hallway width is 37 3/8″. Please see attached image that shows where would the planks land with the line in center of hallway. Planks are in red and the snapped line in blue.
  • Carlos
    May 30, 2024 at 12:19 am
    This is how it looks like if I move the line about 4 1/2″ to the left.
    By the way, what you say the plank should hit the door jamb, how deep should it hit? Like, how many inches into the door jamb?
    May 30, 2024 at 8:25 am
    • Carlos
      May 30, 2024 at 9:31 am
      Hi Joe, thanks for replying. It’s been very helpful. I know I have a lot of questions, but once I start, I’ll get the hang of it.
      I have this hammer, how is this different from the ones you suggested?
      https://www.estwing.com/product/rubber-mallet-hammer-black-gray/
      Another question. To get the staggered look, do you follow a formula or pattern? I’ve attached an image. The red plank is my very first plank leaning against the wall, right? If I use a full plank, then the others should be off, how large should the ones in green, for example? Should I cut a bunch ahead to save time and what size?
    May 30, 2024 at 9:56 am
  • Carlos
    May 31, 2024 at 12:00 am
    Hi Joe, I did some more simulations and it seems that I found the sweetspot and hit the jackpot! Or not. I am able to hit both doorways (red) and I get a 3/8″ gap on both sides (green). Is that too risky to have that gap covered by the baseboard? I was not planning on using quarter round, just the baseboards. Or should I move the line (blue) a couple of inches to either side?
  • Carlos
    May 31, 2024 at 12:08 am
    Another question: I know we want to avoid slim pieces, like 1-2″ wide planks. What if we get a 1-2″ gap in the other direction, across the plank? Do you know what I mean? We are laying a full row of planks and we get to cut a very short piece at the end?
    May 31, 2024 at 9:16 am
  • Carlos
    June 1, 2024 at 8:43 pm
    I’ve been playing with the hallway line and if I move it a bit, I either end up having a full plank inside my door jamb or a less than 1″ wide plank at the end of the room.
    I figure that if I start 3/8″ from the wall, it will end on the other side with a 1/4 gap. Here’s an image of how the planks would be in the door jambs. I think it is pretty good.
    If I choose the take this route, can I start my very first row in the left wall using the spacers? In this case, would I need to screw the scrap pieces?
Page 1 of 2
