Blueprint Request and other questions
Thanks Joe for creating this platform. Your videos are well done and helpful. On the attached file (yellow highlighted areas won’t receive laminate), I’m thinking of starting where I’ve drawn the first row of tiles in red and would continue in that orientation throughout because the narrow part of my hallway is short. Let me know if this is the best place to start and if this layout works esthetically. I have no trim(baseboard, casing, etc), appliances or furniture as I’m finishing a basement. This installation will be on concrete. Additional install info on attached file.
I didn’t notice any videos on drop and lock systems. Any differences in the install instructions? Do I still use the beater block?
Stair instructions for my bullnose and drop and lock system with bull nose pieces please (I didn’t see any stair videos)?
I have an under counter fridge. Should I install this all the way under the fridge (not installed yet) or just to the front as you show installing to the dishwasher in one of your videos?
For my office and bedroom sliding door guides, can I epoxy these to the floor and install the laminate around them? These floor guides keep the doors tracking straight through a slot in the bottom of the door.
I purchased the needed tools through your website links but didn’t purchase the adhesive. I’m assuming I’ll need this for the stairs. If so, can you give me an estimate of how many tubes I should purchase? Is these adhesive needed or recommended elsewhere?
In a ten foot run, how much can you alter a rows positioning at the end without jeopardizing the connections and stability of the floor? (In one of your videos you show moving the tile to be parallel to a line in the bathroom). This info will help me plan my positioning because I’m assuming my walls aren’t a perfect 90 degrees.
Sorry for all the questions, but I noted questions as I went through your videos. Hopefully this will save us both time.
This discussion was modified 1 year, 2 months ago by
jdcart4321. Reason: add additional files because additional pages of original weren't showing
