Blueprint request
Could you please give me instruction on where to start with this project, the first attachment includes the blueprint and images for the main floor, the other attachments labeled ( Bath 1, 2, use a different flooring that is sized like tile.
A few questions i have
1. the image that shows where the flooring ends at the carpet going downstairs, would you install it the same way as showed ?
2. Could you specify where i should have joints between the doorways, i would like to install without transitions on the main floor.
3. Im curious how long an install like this would take you if you’re alone ?
4.There is no urgency at all with this blueprint, i will not be starting for another 2-3 weeks.
5. Would you tear out this existing plank or install over it ? i assumed i would be tearing it out. the existing flooring seems to be a vinyl plank
Thank you !!👍
