There are some videos out there that give several methods you can use. Here is one that you can check out – https://www.youtube.com/watch?v=virO6RGakXU
Otherwise, using wood filler is a good option. You can also remove the trim, cut the nails holding the casing and reset the door. Sometimes that is the best option, especially when you have multiple doors.
Hi Joe…Thanks again for all the help while I was installing my LVP flooring. I do have one question regarding some planks not being connected as good as they were before the cold weather came. Is this normal when temperature changes from warm to cold?
There is always movement of the house when the cold comes, but the plank should not come apart. Can you share some pics?
