Activity Feed › Forums › General › Blueprint Request
Blueprint Request
Posted by brody on March 9, 2023 at 9:13 amI marked out the changes that were not on the blueprint. it was mostly the removal of a wall and some cabinets. Thanks
Joe replied 2 weeks ago 2 Members · 11 Replies -
Hey Joe, Thank you so much for your help. That one area that you were talking about in the beginning is a shower. This is new construction so no cabinets are installed, thinking we will do those after floors. Here is a photo of the type of floor & only thing I failed to mention is the drywall doesn’t go to the floor it end on a z-bead & we want the floor to run under it. I will get a photo of that as it’s hard to explain tomorrow. Also like the idea of running N-S starting in that room furtherest to the west like you suggested as the way you would do it as well. Thanks again
hey Brody,
do you have a full piece so I can see the locking system on all 4 sides?
Here you go, this is also the z bead trim that we want the floor to go under, where the drywall ends.
Hey Joe thank you again for the help. Yes concrete slab & also the floor is going under that z bead & no trim. Thank you
