Blueprint Request
Hi Joe! Hope all is well. Attached is my (not exactly to scale) floor plan where I’ll soon be installing 9×72 angle-tap click LVP. I have no preference as to which direction the LVP is laid. I’m installing throughout except where marked n/a. I have a few initial questions, but please let me know what else you might need from me to get started. Thanks SO much!
Q’s:
– I’m installing over older oak flooring in very good condition. As solid as it is, my home was built in the 1930’s and I don’t expect it will be perfectly level throughout, but the LVP does have a built-in underlayment (1.5mm IXPE). It’s also not going to be possible to run perpendicular, as my original flooring is laid with a decorative border pattern in all rooms. Would additional underlayment be advised, or do I run the risk of feeling springy when walking?
– I live in a very dry climate with central heating and air – With this in mind, what, if any, expansion gap do you recommend?
– What distance apart do you recommend the planks are laid? I’m assuming it depends on the plank width?s
