  • Andrew
    September 27, 2024 at 2:09 pm
    September 28, 2024 at 4:34 pm
  • Andrew
    October 1, 2024 at 10:20 am
    Thanks, Joe! You’re very welcome for the business! <div>
    </div><div>Yes, it’s a new design/build that I’m doing myself, and I’m almost finished with it after a year and a half…</div><div> </div><div>For the puddle areas in the concrete, it is over many feet to get that 1/4″ drop. The double wide power trowel made it very smooth and piece wise flat, but there are a couple of low spots that only water can show with puddles. Using a 4ft level, you can’t see a gap, but you can see the bubble tilt a little bit.</div><div>
    </div><div>Yes, in a few months, I’ll continue the plank up into the chaple. I’m just holding off on that room so it can be my paint booth for this winter. I just want to end the plank in that room, bit start in that room. </div><div>
    </div><div>The screen porch is outside and will just be a concrete slab. </div><div>
    </div><div>The plank will continue into the Mudroom and will most likely go into the utility room. </div><div>
    </div><div>I already have all of the plank for the install, so I’m not super excited to do the glue down in the laundry room, plus that would add a transition to that doorway. </div><div>
    </div><div>The 6ft level is centered over the laundry drain. On the right-hand side, you can see 5/8″ for the gap in the laundry drain. Would you do the Henry 549, or just use thin set since I already have that on hand. </div><div>
    </div><div>Color matched silicone control joints between the shower tile and LVP are perfect. It’s a good idea to do silicone instead of grouting right up to the plank.</div><div>
    </div><div>You said that the Adura Max won’t expand and contact much, which is great. I don’t think my house will move much either, though, since it’s ICF walls and not 2x6s.</div><div>
    </div><div>I see what you mean about working the east/west planks from north to south instead of south to north, I would probably go with that method. </div><div>
    </div><div>However, running the plans north/ south and then moving from the kitchen to the chapel does look easier. I would stagger the joints down the main hallway to add a random pattern to that. </div><div>
    </div><div>Which way do you think would look better, running the planks n/s or e/w? Or do you think either way would look good and there isn’t any real difference between the two ways since it’s 3k sq ft and there are so many different rooms competing for different directions? </div><div>
    </div><div>Thank you so much, </div><div>Andrew</div><div>God bless!</div>
    October 1, 2024 at 10:50 am
  • Andrew
    October 1, 2024 at 3:37 pm
    For the laundry room, I removed the drain plug for the picture, but I’ll use that when filling the area in. The final drain insert screws in and allows for a final height adjustment. I don’t remember what that is at the moment, but I’ll calculate it before filling the area.
    So, just to confirm, if you looked at this house for the first time, you’d assume that the planks should be running east/ west, lengthwise down the hallway, for the best look in the kitchen, living room and hallway. I can make any direction and start point work, I’m just trying to make sure that most people won’t say, “Why did he do it that way….”, especially my wife 😉
    If I do lengthwise down the hallway, I’d start in the living room and then work into the kitchen area just to minimize cutting when starting.
    Thank you!
    October 2, 2024 at 8:46 am
    Yes, I would run it east and west
  • Andrew
    October 2, 2024 at 9:46 am
    Awesome, thank you!
