2nd floor bedroom and hallway project
Good Morning Joe,
Thank you for all of the valuable information you share with us. My wife and I were going to have this large job done professionally, but with the costs of insulation we would have had to spend less on the vinyl planking. We felt that a quality product was more beneficial, but we would have to spend a bit more. With that it was decided that I do the install and we would put that money saved from the installation into the product.
We researched several brands, but settled on the Mannington Adura Max. I seen that the Mannington product was one you felt was an excellent choice of flooring. My wife also looked at the Flooret products, but could not find a color to her liking. I believe the Adura Max is a drop and lock locking system.
I am replacing the carpet in all of the second-floor rooms, and was going to replace the carpet on the stairs as well with a vinyl plank. After researching what needed to be done to place vinyl planking on the stairs, we decided to have someone come in after and install carpet back on the stairs.
That actually brings me to my first question, should I have the carpet placed on the stairs first before I place the planks? My thought was walking up and down the stairs with work boots on new carpet might not be a good idea, but if the job will go better having the carpet done first, I’ll get someone in right away to do that. As long as I am talking about the stairs, I have two more questions first how do I proceed with the landing between the two stair flights? I want that to be the planking from the second floor. Is there anything I need to pay attention to here? Second how do I do the transition at the top of the stairway? How close do I come to the stairs at the top?
I have removed the carpet from two of the four bedrooms as well as the hallway and stairs. I can remove the carpet from the other rooms now as well, if need be, but my thought was to place the furniture in the two empty rooms once the flooring was done instead of moving it downstairs like I did with the first two rooms. If I should start in one of the rooms that still has carpet and furniture in it I will easily get that done. I should mention I am retired so time really is not an issue for me and we know this is going to take some time to complete.
My wife is thinking she would like transitions between each room even though the flooring will be the same throughout the entire upstairs with the exception of the bathroom off the hallway which has linoleum, that will eventually be replaced with vinyl planking. I plan on doing that at a little later time. The master bath has a laminate I did a decade ago just winging it. I hope this job turns out better than that one, but it has served us well to date. What are your thoughts on transitions between all the rooms? Is this something that is usually done or is it even advisable?
As for the direction of the planks we thought the planks should run west to east down the hallway. As to where to start, my best guess would be one of the two front bedrooms, or one of the two back bedrooms. I will wait for your advisement on that as well.
I also have a question concerning some dips in my subfloor. I’ve noticed in some spots there are between 1/16<sup>th</sup> and 1/8<sup>th</sup> in dips. I know you mentioned I can use tar paper underneath. I’m not sure how comfortable I am working with quickset so would tar paper in the low spots work here? I also included in one of the pictures some circles in the subfloor about the size of a quarter and 1/8<sup>th</sup> inch deep. There are about 15 to 20 of these in the one room. Should these be filled in or covered?
I know I’ve asked a lot of questions, but I’m trying to be as prepared as possible. Thanks for your help.
Rick
