  • Posted by Josh on February 9, 2021 at 6:26 pm
    Joe,
    Thanks for your videos! I haven’t started my project yet but feel much more prepared already having watched most of the videos.
    Would you give me some advice on our project? We have about 1,400 sq ft of MSI Prescott line LVP with attached pad that we’re installing throughout the house (except for the two bathrooms). I’ve watched your videos and have four main questions:
    1. Is my thought process correct of starting the first line down the hallway into the kitchen (see attached rough drawing) and then working backwards into the laundry room, master bedroom, master bedroom closet, and the stove/refrigerator nooks? And then working forward into the rest of the house (rest of hallway, kitchen, dining room/living room, and the two bedrooms)? I was originally thinking of trying to mark off from the main line in the hallway/kitchen into the master bedroom and working forward throughout the house. But there’s not a clear shot from hallway into the master so I’m concerned I could have my measurements off by even a little and it look funky when I get to the hallway/main part of the house. Not necessarily looking forward to working backward through the master and laundry room but the videos you posted don’t make it look too hard and I’m not afraid of it taking a little longer if it ends up perfect in the end. 🙂
    2. What should we do with the doorjams that are going to leave a gap between the LVP and where it was cut? We currently have engineered hardwood in the house (which our German Shepherds have destroyed). It’s ~0.5 inches think. The LVP (with the pad) is ~0.25 inches thick so we’ll have ~0.25 inch gap after installation. Should we fill that with wood filler and repaint? Replace the entire doorjams (about 5)? Leave it alone? Any thoughts would be helpful. Note that we’re already going to remove all of the floorboards anyway and replace all of those after the LVP is installed.
    3. Do you have any recommendation on ripping out the old engineered hardwood and removing the glue (not a floating floor)? I was thinking of setting the circular saw to just shy of the depth of the engineered hardwood and rip cuts throughout the floor. Then pry the pieces out. Not sure though on best method to remove the old glue….
    4. How do I end the LVP at the front door and the sliding glass door in the dining room? I have T-molding for transitions between the bathrooms and the LVP but not sure about the other entryways. Note I’m going to follow your technique of cutting into the fireplace (it’s thin brick) to slide the LVP under it so no trim is needed there.
    Thanks again!
    Josh
    Joe replied 3 years, 10 months ago 2 Members · 6 Replies
  • 6 Replies
    February 10, 2021 at 1:18 pm
    I am working on this right now, is the engineered floor all throughout the areas that are getting the plank? Also are the door jambs painted?
    February 10, 2021 at 2:03 pm
    Here is a link to a screencast answering your questions.
    http://somup.com/crn6YVD6Ug
  • Josh
    February 10, 2021 at 6:07 pm
    Thanks, Joe. Sorry about not being more clear in my original post.
    The engineered hardwood is only in the hallway, kitchen, dining room, and part of the living room. The bedrooms and rest of the living room are carpet and the laundry room is bare concrete at this point. Everything is on a slab. The doorjambs are all painted white.
    That said, we’ll have to remove the engineered hardwood.
    So at this point I think I’ll try wood filler or caulk on the doorjambs and see how it looks. Worse case I’ll rip it all out and replace it.
    Do you have any recommendations on removing the engineered hardwood and glue? Not sure how often you’ve been blessed with that task. ????
    Thanks again for the excellent videos and personal communication. I’ve already recommended your site to two others who are facing LVP installs in the near future.
    Josh
    February 10, 2021 at 7:37 pm
    Thank you Josh!!! It will be kind of difficult to cut the wood without hitting the concrete at some point. With that being said you could buy some cheap blades for a circular saw and cut the floor into small sections. Like 2×2 sections. Or just one row at a time brother.
    It would be very similar to tearing out vinyl and quarter inch underlayment. Check that video out.
    https://laminateuniversity.sothatshowyoudothat.com/how-to-demo-existing-floors/
    How to demo existing floors
  • Josh
    February 21, 2021 at 2:27 pm
    Joe,
    Do you have any advice on whether or not we need to remove the glue residue?
    We’ve ripped out the engineered hardwood and have the glue still on the floor. It’s spongey/rubbery but not sticky. We’ve started to remove it in the dining room but it is a process.
    I’m wondering if we can simply install the floating floor on top of the glue (scraping off any high points). We put down about 6 planks to test over the worst part of the house and couldn’t feel the glue underfoot.
    I don’t want to have regrets after the project is over so if that means spending the extra time and muscle to scrap off the old glue, I’ll do it. But if it won’t make a difference I’d rather not do it. ????
    Thoughts?
    Josh
    February 22, 2021 at 9:19 am
    Yes you can leave it! Watch this.
    http://somup.com/crn3oFDwmZ
