Another question I meant to already ask is whether or not I should put down an underlayment. The manufacturer states, “Do not install SPC flooring over carpet or any foam underlayment.” It also says, “Restoration SPC flooring includes a pre-attached 1.5mm Ethylene vinyl acetate (EVA) sound mitigating underlayment pad. Do not use any additional foam cushioned underlayment, as it will void the product warranty.” I have heard you recommend putting down underlayment in several videos before, not sure if the underlayment you recommend is “foam underlayment”. What’s your opinion on this given the above information from the manufacturer?
Thank you,
Jason
