Activity Feed › Forums › Where should I start – Post drawings and questions › looking for suggestion as to where you start › Reply To: looking for suggestion as to where you start
I just watched your video, and there is alot of good info. i was out of town until last night, but i will probably start late today or tomorrow. I plan on starting in the first bedroom, the only issue is that the outside wall is off….i measured two spots from top wall to bottom wall in that bedroom and the right side measurement is 135 1\4, and the left side is 134. should I measure a line from the inner wall so the angled piece stays on the outer wall? Also, the plank i have has padding, but there was a question in the forum saying that we should use padding….I would like to use quiet walk, but i would like the experts opinion…thank you in advance joe!
