Activity Feed › Forums › Where should I start – Post drawings and questions › Blueprint request › Reply To: Blueprint request
Hello Joe, started cutting the door jambs and I have a question on what to do about the front door threshold. Should I try to undercut it with an oscillating saw or cut off the front part of the wood and add a new piece like I did on the back door when it was replaced? It seems like it would be hard to undercut and look good. Did take your suggestion and found a plank cutter on amazon for around 100 dollars that works great, lot easier that a utility knife.
